Vokera Linea 28 (Central heating boiler)
6 Feb 2008
Renfrewshire
I have a Vokera, Linea 28. It is gas supplied and have had the unit for 5 yrs.My hot water side of things function corretly, however, my heating will only activates correctly when I turn up the thermostat to full (i.e 85deg and down to around the 70 deg mark).
I suspect the potentiometer(advice by friend)
I assume it is one of the PCs (burner control board)???
if changing this........ ensure all power is switched off and gas supply isolated.
Please HELP soon as my house is either a hot house (grow tomatoes,) or the penguins are sitting beside me watching telly
Have you had a new PCB fitted recently?
The stat knobs can be put on incorrectly.
No. Just a bog standard combi boiler which only heats up if the thermostat is fully clockwise ie turned up full.
thanks for helping me out so far
Presumably when you say the thermostat you really mean the heating control knob on the boiler?
Have you measured the resistance of the temperatures with the boiler cold?
Tony
Yes, just the knob on the boiler I am talking about. I havent measured any resistances, but the hot water part of it is fine.
The hot water may well be find but its the heating which is your problem so measuring the sensors cold would be a simple start!
Tony
