I have a terrace house with single floor extension out back with a bathroom, small utility closet and back door within it (I'm sure most of you know the type -- typical 2 up 2 down).
The bathroom has no ventilation other than a window and the utility has none.
The shower is on the wall that goes through into the utility. It's my plan to knock a hole through the top corner of that wall and install an intake vent. From this I went to use 100mm fexi hose that runs into an inline fan in the utility room.
Out of the fan I wish to use more fexi hose that runs to the ceiling from the fan and into a Round to flat vent converter. The flat venting then runs through the 2nd stud wall out of the utility, across the 1M wide hallway, back into another convertor that goes through the external wall and into the external vent.
Edit : There is a 3 pin wall plug socket in the utility closet. I plan on running power from this into a 6A Fan Isolater Switch, which in turn is wired to the fan. Is this the correct method for this?
My main questions are
1) Can I wall mount the inline fan? Or should I run hose to the floor, floor mount it and run hose back UP the the 2nd wall in the utility?
2) In the future I wish to T junction from the fan outlet so I can plug a dryer hose into the vents. When I turn on the fan it should take out all the moist air from the dryer with it. Is this a good idea? Would it be better in front of the fan...i think that could blow back into the bathroom?
3) I'm scared of making the hole in the external wall. It's double bricked. I've looked into core drills, but I've never done anything like this before. Any tips?
4) The hole from the bathroom requires me to go through a tile. How could I go about this?
Sorry for all the questions. But I'm a computer techie and not so confident around manual labour!
