Distance from CU to Shed is 6M. nothing big plugged in there ( no welders for instance, just normal hand power tools like drills, jigsaw etc.
Cable will go underneath the floor of the Kitchen/Bathroom extension of a two-up two-down terraced house and through the wall directly to the adjoining Brick-Built shed ( using the end-wall of the extension for one side of the shed ) and terminate on a 6-way CU with an RCD fitted.
Would the house earth carried from the CU in the cpc be OK for this or would I have to provide a new one situated in the shed ?
As far as I know I have a TNC supply if that needs to be taken into account.
This cable is going to replace a totally unsuitable feed that I found which consists of 4mm single cables taped together. It was noticed by RF Lighting in my original thread HERE
Thanks as usual guys.
