Hi all, first post so go easy! I do alot of work in the local Mcdonalds stores, repairing leaks, replacing taps, unblocking wastes etc. One of the newer stores has a Megaflow fitted that has an immersion with a faulty element (as identified by an electrician). I'm going to replace the whole immersion, but i've never done this on a Unvented cylinder before only on a standard copper vented cylinder so would like some advice if possible.
I've heard Megaflow do a push-fit immersion type for some cylinders. It looks like it's threaded as I can see obvious way a push-fit type would stay in there, is it likely to be threaded or push-fit? (it's a 300 series, 6-8 years old)
Also, as it's in a Mcdonalds draining down/turning off the water is an issue so is the immersion in a dry well or will I need to drain down?
I've been a Gas Engineer/Plumber 9 years and this is the first replacement immersion that's needed doing on an unvented cylinder so I realise the questions might be somehwat basic but i'd rather go in to the job with slightly more knowledge than I currently have.
Ta!
Ta!
