an unvented cylinder of a vented thermal store
What is it then?
It is a sealed thermal store, but would you and Drivel consider these as dangerous as they have the same capability to explode as an unvented cylinder, in fact it has more risk, it has less safety devices as it does not come under G3
A lot less dangerous as you only have handful of them installed in the country compared to the prolific installation of UV cylinders being fitted by every tom, di@ck and harry who haven't a clue.
So danger only occurs when it is in quantity does it,
it only takes one to go badly wrong to be dangerous,
so whether there is 1 or 1,000,000 makes no difference,
so are you saying that they are safer in your opinion purely because there are not so many installed
Vented systems, my word you are prehistoric, vented system sludge up, they ingress air and are unreliable
You have answered your own argument, it only takes an inferior installation to make one dangerous,
this applies to vented or unvented,
but the only ones I am aware of are vented systems that have been installed poorly that have become dangerous,
I am not aware of any unvented cylinders being dangerous through poor installation and neither are you,
otherwise you would be able to point us in the direction of the proof, something that you and drivel have failed to do.
No check valves on the cold feed or mains then drivel/balski
