ok thanks. is it hard to do? i know when drilling through a normal wall i make a sligh indent with a bradle first so the drill doesn't wobble when first started! any other tips for it? and after inserting the pipe through what sealant/filler is best advised to seal the gap between the pipe and wall??!
I always like to see the look on a customers face when I tell them that as I have broken the core drill for a 40mm waste I will have to use this one. Then show them my 150mm one
