- Joined
- 18 Nov 2007
- Messages
- 929
- Reaction score
- 28
- Country
I was planning a new complete shower with cubicle but that is going to be one hell of a big job routing the pipes and what not so Have decided to opt for a mixer shower to go where the bath is for the meantime.
My current bath is in a corner, see poor effort of an illustration below
My proposition is to create a stud wall behind the front of the bath where the mixer shower can go, and tile it all up then stick the mixer shower on and this will give me good access round the back to get at the plumbing.
Now my questions are for the plumbing side of things.
Would I be able to run a feed off the bath's hot/cold taps straight to the mixer shower? There are about 3 connections to the main cold and hot pipes from the boiler already i.e. two toilets, second sink...
After having a comi boiler fitted, has left a very poor flow for hot water, the pressure is so bad that I can only turn one tap on at a time.
I'm assuming this will be an issue with a new mixer shower but wondering if i would be able to get away with it as I know many people with combi boilers using mixer showers fine.
What other options are there for me if the pressure is not enough? Pump?
Any tips help and advice would be most appreciated.
Cheers
Cheers
