Hi
I resently installed a Vaillant 438 with s plan. The customer had an old weather compensation unit with his old boiler and wanted the same set up with his new vaillant. I was recommended to use the VRC 400 from Vaillant themselves. I installed the VRC 400 unit as a room thermostat in the hall. I didn't change the cylinder as it had been replaced not long before the new install.I followed all instructions from Vaillant and installed the VR65 wiring centre and used a honeywell cylinder stat. Everything seemed to working fine.
But now the customer has been back in touch complaining about his hot water. Since the outside temp has increased the flow temp has lowered to around 50 degrees and as the room temp reaches the target temp the flow temp reduces even more down to 35 degrees. So when he has his heating on and his hot water on when it is a warm day and the house is almost to temp the water circulating through the cylinder cools the water down.
Has any one else had problems like this or can anyone explain more about this weather compensation unit.
Richie
Richie
