No heat in downstairs radiators
13 Apr 2007
Armagh
We have a small two bedroom terrace house that we rent out. This has oil fired central heating system with which there seems to be a problem.
When we turn on the heating the burner in the back yard fires up and starts heating the water. The upstairs radiators will heat up fine but not the downstairs ones. Downstairs we have a double radiator in the living room and a single in the kitchen. All radiators in the house have thermostatic valves fitted and all valves are set to their highest which is 6. All radiators are turned on too. The pipes coming up from under the floor to the downstairs radiators don't even seem to be warm!
What could be the problem with this? Would it be that some of the radiators need bled?
try shutting all the upstairs rads. to force full flow round the bottom rads.
see if they warm up then
Thanks, I'll give this a go this evening when I get back to the house. If this fails, is there anything else I can try?
So I take it the heating system all runs in a circuit with the hot water going to the upstairs radiators first and then going back down through the downstairs radiators and then out to the burner again?
where is the pump and motorised valve located is it upstairs in a airing cupboard with copper hot water cylinder ?
I'm not sure, I think it may be located in the upstairs airing cupboard with the copper hot water tank.
Also, beside the hot water tank there's also a small red cyclinder about the size of a football. There's also a pressure gauge on this. Would this have anything to do with it?
Sorry, just one more thing.
The only thermostat in the system is in the burnder which is located in the back yard. This can be turned to 60, 75 or 90. What exactly does this do? If it's set to 75 will it stop burning when the water hits 75 degrees C?
What should I set this to?
