Vaillant VUW GB 242e / 282e Water pressure too low
25 Apr 2008
Avon
Hi All,
I've just moved into a new house which has the above combi boiler. When cold the system is at about 0.2 bar, and 0.8 when hot.
I've looked everywhere to try and find how I increase the pressure on this model, but can't find it anywhere!
Would someone kindly point me in the right direction. A diagram would be helpful.
Thanks in anticipation
onthe1st
Somewhere near the boiler i would imagine that there is a silver braided hose with a tap on it. This is whats used to top up pressure.
see FAQs
filling loop should look something like this
follow pipes from boiler and you should find it.
HI
vuw turbomax ??it has internal filling loop.looking at the boiler first and second pipes from right hand side (bottom of the boiler) there is a place for the filling key.if the key is missing then use a flat head screwdriver and open both valves .you should be able to hear water being filled.
Thanks everyone for your replies. It seems the previous owner disconnected the loop and connected an external water tap to the supply!! - as soon as I saw the picture I knew what I had to do.
All sorted, once again many thanks
HI
The turbomax plus has internal filling loop
HI
I have the same pressure problem but I don't see a key or something to use a screwdriver with :-( Can you please help me? I have Vaillant UTRBOmax VUW 242E/282E.
THIS SITE WAS VERY HELPFUL TONIGHT -- AND JUST WANT TO CONFIRM ON THE OLDER MODELS VALLIANT 282 WITHOUT LED READOUT. BLACK CONTROL PANEL AND GREEN DIALS. THE FILLING LOOP IS EXTERNAL, FLEXI HOSE WITH TWO VALVES AND MOST LIKELY BEHIND THE WASHER OR UNDER THE SINK.
THANKS
Thanks for the tips. I also had the external hose and this thread resolved my problem! Cheers!
