I have the above boiler providing intermittent hot water. The central heating works fine and the hot water used to be worse when the central heating was on at the same time. With the warmer weather the ch is now off and the hot water WAS being more behaved. Unfortunatley now its getting worse again.
The boiler fires, cuts out, fires, cuts out and then eventually fires for 60 seconds or so then cuts out. The system pressure is good @ 1.5 bar.
After a few minutes of this it will eventually sort itself out and keep the hot water flowing.
Suggestions please, is the first thing to look at the diaphragm?
Cheers
Phil
Cheers
Phil
