just need to quickly check something if possible... when turning hot water ON from the programmer the 3 port mid is already open to H/WATER? So SHOULD the orange wire be live??
Well said.motor only energises for c/htg, the 240 is on orange because it comes straight from cyl stat
Only because it is connected to the same terminal as the boiler!orange wire live when ever demand for the boiler to fire
so there for it is always live when demand for boiler lol as per the statment .not only live for heating as someone said!!
What is the point in giving an answer which, although correct is "economical with the truth"?yes i agree but if you read the initial post the question was will it be live when hot water on.the answer is yes unless you want to tell him no and let him find out the hard way
