Back panel off, belt off, 2 hex head screws hold motor to outer drum, unplug motor from wiring harness, remove motor, each brush is held with 2 screws which may be torx type. You need to check which motor you have as there are at least 2 makes, Hoover or C.E.S.E.T.
Hi thanks for ur advice i have done the brushes on the washing machine it was easy the machine was my 72 yr old parents and they say thank you .
Im a 43 yr old woman and if i can do it anyone can...
MAKE SURE YOU SWITCH THE ELECTRIC PLUG OFF AND REMOVE FROM THE WALL !!!!!!!
