DIY - Bathroom installation - General plumbing Question
3 Dec 2006
Liverpool
Hi all
I started to clear out my bathroom this week and plan i DIY job for a full refit - bathroom suite, flooring, tiling - the works! - And im knackered already (its only Tuesday) :oops:
The room is now pretty much empty bar a few capped off pipes and i am now doing the pain staking work of preparing the walls for tiling and fitting a new window.
I am needing to decide where the sink, toilet and bath feeds will need to be located soon as i will be wanting to fit laminate flooring in next couple of days. I want to move the existing route of the pipes to reduce boxing in. The hot feed is 22mm to the bath, with a 15mm running from it to the sink. On further examination under the boards the hot seems to originate from a 15mm pipe increasing to 22mm - Is there a need to keep it this way? any benefits?
The reason i ask is that i need to take it back to the point where it is 15mm in order to re-route, so therefore if there is no reason to increase it to 22mm i wont. It seems that in the past, the length of 22mm pipe had something else running from it, but this is now capped off.
any advice much appreciated.
Ste
Where is your bath hot water supplied from?
Open vented cylinder?
Unvented cylinder?
Heat store with heat exchanger?
Combi boiler?
Regarding capped-off dead legs, I would remove them - they're not healthy, with a risk of Legionella in the worst cases.
Hi Softus
thanks very much for your reply. I have a combi boiler installed. When i looked under the boards there are alot of old pipes as the house recently had a Combi and Central Heating installed including all new pipes. I have got rid of loads of dead pipes over the last few days.
Like i said, i have traced back the Hot supply in the bathroom to find it originates from a 15mm pipe, incresing to a 22mm. It has (as you say) a dead leg of 22mm then leads to the bath. I need to cut the pipe at the point of it being a 15mm in order to re route to the sink and bath. I am not sure if there is a need to increase back to 22mm - would they be any benefit? any point?
In doing this i will also get rid of the dead leg, thatnks very much for the advice on them being a potential problem - i was not aware.
Many thanks
Ste
Don't dump them - you'll get more money that you'd expect from a scrap metal dealer.
No - as Bahco has observed there is no benefit in inreasing to 22mm. In fact, there's a benefit in keeping it to 15mm, as long as its lagged, because there will be a shorter lag in delivering hot water to an outlet when the pipework is cold.
Thanks alot guys, it REALLY helps to have your input :D
It does surprise me just how littling lagging is used throughout the house, even with a new CH/Combi boiler installation. Do plumbers lag pipes as standard? (Just a general newbie question)
Thanks again, quite looking forward to taking these pipes tomorrow. Not looking forward to the tiling though :?
