I've got to run a section of 2.5mm final ring chased into a wall that (as a result of a window and expensive coving) can't be run in safe zones (also not possible to run under floor).
The run is between 2 sockets on the 2 adjacent walls.
2 obvious choices are:
1. Add an additoinal socket to the intermediary wall which means I can then run horizontally between the 3 sockets.. but this may not be asthetically OK... or
2. mechanically protect and earth the intermediary run.
...but the only problem is that even 20mm steel tube would exceed the 1/6 rule that BC mandate for horizontal runs (even with plaster)..
The alternative is to use something like http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0615602
but this is expensive...and although it looks like it would easily meet the mech protection requirement, I'm unsure what BC woudl say.... opinions, advice (tell me that I've got it all wrong.. again!) welcome.[/url]
