Hi Ellie74
I am stripping wood in my Victorian house. After a little trial & effort, I use a heat gun first to get most of the gloss off. I do this with the windows open and the back door too, to make sure I get a good flow of air through the house. And also I break the task up so I'm not doing it for hours and hours. I use a combination shavehook for all the curves (as an aside, do they all come with the same configuration of blade?) and a triangular one, which is better at getting into the very tight grooves.
I then use Klingstrip- it's a poultice type stripper- it has a sticky putty texture, spread it on with a flexible spreader, cover with plastic (I use bin-bags cut into strips) and leave for a couple of days. Then scrape off the residue, and finally scrub the wood down. You may need to go back to wash off a bit of effluorescence that appears, but the wood comes up really well. Sand with coarse and then fine sandpaper. I find the sponge blocks helpful to get into some of the nooks & crannies.
I've yet to decide how to finish off the wood I've already stripped- I'm going to post a question on this very topic!
