I have a start problem with a Baxi solo 2 50PF, "boiler on" light is on and no others. Pump runs, fan doesn't checked voltage across fan and none present. Checked resistance across thermistor (o.k@1M Ohm), across pillot solenoid (o.k @1.5kOhms) continuity across overheat stat (o.k) Also checked potentiometer and o.k at 0 and full range. Replaced pot and thermister just in case, no result, suspected board (already replaced 18 months ago), bought a service exchange for £40 and swapped out, still no joy.Now beginning to suspect fan motor....any suggestions or anyone had a similar fault, I haven't checked the loom yet but will do next before I think about fan replacement.
