Hi people...new to the forum.
Can anyone help me please..
My Baxi Solo 2 50PF will not start. The boiler on light is on and the system is calling for heat but the fan doesn't start or even try to, nothing happens at all. Obviously if the fan doesn't start then the pilot doesn't light etc etc
There is live and switch live.
The control valves open, pump runs but the boiler does nothing.
I have checked the potentiometer switch, thermostat sensor, pilot and main gas solenoids, overheat thermostat and all are ok. I'm presuming it's the PCB but I don't want to change it for nothing.... I expect they're expensive.
The only thing I haven't checked is the pressure switch cause I'm not sure exactly what I should do.
Point to make: For some reason my pump isn't wired from the boiler and is always on..... strange I think...... but it has worked for many a year so I don't think this is anything to do with the problem.
