I was kindly given a brand new shower by a friend. However on inspection I will need to upgrade the loft tank to a larger size (50gallon) to avoid problems with cold water supply.
Currently I have an old asbestos tank (25gallon) which I will leave in the loft until I can get it out safely and just extend the current connections to the new tank.
I want to raise the height of the tank to maximise hot water pressure into the mixer shower and therefore need to build a set of stilts for the tank to sit on bearing in mind that its going to be minimum 240kg when full.
I need some help to design the stilt construction so that the load is spread across the building. Any ideas?
Brian
Brian
