I have leak with my water / central heating system. It's 3 years old now in a new build flat.
The leak is coming from something called the Cold Water Combination Valve. It's a very slow drip at the moment.
The system has a Megaflo CL145 unvented cylinder and above that is a varem expansion tank.
The pressure gauge connected to the varem is reading ok for PSI but 0 for bar.
I've tried regenerating the airgap in the system a couple of times but its not helped. I think the 0 bar reading is my problem.
Water pressure seems fine and I have hot / cold water as well as heating.
Hear an occasional loud bang when running the hot water not often though.
Photos attached of the system here:
//www.diynot.com/network/bungledoe/albums/
Can anyone help me??
Bungle
Bungle
