Pipe banging
SMG
31 Oct 2007
Manchester
I fitted a Prestex P404 TRV under my wet-room sink. Water pressure is a steady 3 bar, balanced hot / cold feed. Before, there was no noise, no hammer, now, whenever I turn the tap off, I get pipe bang. Just one bang each time, & it only does it when the tap is on hot (Mono tap with 10mm tails).
I have held each pipe to feel for movement, all pipes are clipped & I have no idea where the noise is coming from. Could it be a faulty TRV?
It could be an unsupported pipe somewhere else in the house. If you turn the tap off slowly and it doesn't bang then you need to find where it is doing it. water hammer transmits for a good number of metres from source.
TMV.... not TRV.... God that baked my brain for a moment...
Anyway, as with Pete. Unlikely the valve. More likely an unsupported by or a dodgy flush valve in a loo.
As I have said before. As a counterboy Iheard it all.
TRV, to some, also stands tor Thermostatic Regulating Valve, meaning a TMV.
Try clipping the pipework immediately before and after the TMV (3 clips) to stabilise it. This must be the cause as it is the only difference to the pipework, you've just added a lump of brass to it.
The feed pipes are behind the plasterboard wall, behind the units, its impossible to access them. The only way I could "Stabilise" them would be to drill a few holes, very carefully, & inject expanding foam in, I was kinda hoping the valve was duff.
One thing I don't understand is why the pipe doesn't bang when the TMV is not in place, why would fitting the TMV "create" this effect?T
hanks guys.
(TRV.My bad, should have been TMV)
Just a quick update. I replaced the TMV with another, same banging, fitted another TMV in the upstairs bathroom, lo & behold, more pipes bang. For some reason the TMV is creating the fault, the hydraulic shock,
Without the mixing valves there is no pipe hammer at all? Very strange.
