Our cold water has stopped in the kitchen sink
Underneath, there's no chance of anything being turned like a valve - I've checked and all looks OK.
Hot water runs OK.
When hot water is run, I can feel both feeding pipes, hot and cold running water.
Would this indicate that the cold tap is faulty?
It stopped 1 day ago.
Before that, the tap was stiff... still is... not sure if that had anything to do with it.
Any ideas what I can do before I contemplate replacing?
(Assuming this was the problem.)
Thanks.
Hot water runs OK.
Thanks.
