I’ve got a ecotec and I’ve got no problems with the hot water or central heating. The problem I have is it never turns off for more than 3 minutes, the water pump runs all the time with S07 pump wake displayed and I’ve got no idea why. Had the boiler moved last year when I had work done and I had a few problems with the controller which is a Honeywell evo home, they had to come back a couple of times to get the wiring correct. I know it’s got a frost protection as the boiler is in the garage but the pump wake will run when rad and water temps are still showing high so I didn’t know if it could be a faulty temperature censor or something??? Any help would be great full thanks
