Morning all. Hopefully someone has come across this before..
I have just clad the inside of my outbuilding in OSB3. Wall sheets ate butted together and behind it sits a vapour control layer.
I now want to seal/caulk the joins and paint over. Gaps vary from tight upto 5mm.
Thoughts on what I can fill with without causing the OSB seams to swell... then I need to consider what type of paint I should use. I've heard something acyrlic/oil based is best?
Thoughts?
Thoughts?
