Hello,
I would value some expert insight into an ongoing issue which has now been problematic for at least a couple of years.
Using the pictures/photos as a guide, this is the narrative:
Since we are expecting a new arrival in the next couple of months this is an urgent project and so we are wondering what the best solution is. If needs be we will get a professional in - but then what needs to be done?
Thanks.
- Photo #1 "BedroomDamp". The back bedroom wall was showing obvious penetrating damp. This was ongoing for about 1 year (roughly since Oct 2019)
- Photo #2 "Outside_wall". We discovered the damp was penetrating from the outside wall due to a leaking roof and primarily a leaking gutter; both were repaired in March of this year, 2021.
- Photo #3 "Oct 2021 Damp stains". After these repairs (March 2021), we let the wall dry out for a few months. The wall was clearly drying successfully. I then applied several layers of paint (in May/June 2021), however, covering the damp stains was difficult. I applied both water and oil based Zinsser primer, however, I could not seal all the stains.
- Photo #4 "Oct 2021 Paint cracks". Just this past week (11/10/2021) I noticed a crack in the paint.
- Photo #5+6 "Oct 2021 Loosened plaster"/"Oct 2021 Bubbled plaster". The paint appeared to have bubbled, or more so the case that the plaster has loosened from the wall and was soft to the touch.
- Photo #7 "Oct 2021 Plaster removed". I stripped back the loose plaster which eventually/evidentaly aligned to the original area of damp. The plaster in the top section remains loose and still needs to be removed. (It resembles a map of Italy!)
- Photo #8 "Oct 2021 Wall cracks". The wall appears to be dry, however, there are several cracks while the wall is also cold to touch. There is also a musty damp smell.
- Photo #9 "Oct 2021 Wall dry". Since the wall appears to be dry, I reckon there is no further damp penetration, however, several questions remain: What is causing the plaster to bubble? Does the wall require time to dry out properly? Or should I simply replace the wall as the damage has been done.
Thanks.
