Just lately, every couple of hours or so, I hear the WC fill valve open for a second or two. Looking carefully, I can see that there is a very small leak from the flush valve so the water level is reducing and the fill valve opens to top it up. It’s a back to the wall WC and it’s a real agg to remove it to split apart so does anyone know whether there are any serviceable parts inside (the main seal?) that can be replaced while it’s still bolted in. If I have to remove it, I’ll replace rather than repair but if it’s a fix with everything still in there, I’d prefer that.
