Got this fallen cement. Where are they from?
24 Mar 2025
Hello, I’ve found two pieces of fallen cement. Could you tell me where they’re likely from? Should I be concerned about a roof leak, for example? Many thanks.
I can upload more photos if these two are not clear.
I suspect it's gonna be a bit tricky to guess without any clues, maybe even a picture, about what's above them...
It’s a bit tricky to check unless I climb up, so here’s a photo of the roof.
Could be between the ridge tiles?
The chimney was repointed before, as you can see from the lighter colour of the mortar, and it looked fine.
I will try take some better photos of the roof tomorrow.
