Horizontal and vertical lolThey might be bi-directional but what do they identify as?………
I installed 7 out of 8 of mine horizontally, (on the return.). This particular one replaced one which lasted almost 7 years but wasn't a EPH which I now use.Horizontal and vertical lol
I found on the return, setting the lock shield is harder than on the feed. It could have been the make of the head, I find the speed that the TRV closes means the whole radiator could get hot before the valve had closed, so larger hysteresis on return to on feed.
so that made setting up easier, I slowly closed the lock shield valve, until current never exceeded target, and once set, the radiator only got warm, not stinking hot, and each room was spot on what had been set. This was with a gas modulating boiler, so moving in here, I thought I know how to set up radiators, but no with an oil on/off boiler the TRV does not work as well, it still works, but not like they did with a modulating boiler.
the Kasa and Wiser
both give reports, the Wiser one sorry the heating was not being used, however it does show any hysteresis, the Energenie and e-Q3 do not show a graph, and e-Q3 only shows target not current. However, they cost £15 each in 2019 with bluetooth so what do you expect for that price.If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you.
