Hi all,
I am getting a dormer done in east london, the plan appraisal has flagged up that 1st floor ceilings need to be fire rated 30 minutes. Builder is now under the beleif that the existing ceilings will need to be taken down and replaced with 30 minute fire rated plasterboards. He has mentioned he has not been made to do this anywhere else before and is suprised about this regulation.
I then spoke to the building regs person and he mentioned that it was highlighted in the plan appraisal but if the steels have been painted in fireproof paint (which they have) and chicken wire is laid for existing ceilings then no further measures are needed. Other than the obvious fire doors and alarms etc.
Now the issue is the builder is saying he's not heard of the chicken mesh thing before and he's not even had to ever replace full ceiling with fire plasterboard and is saying we will need to replace the ceilings to fit 30 minute plasterboard. This is coming to an extra 5k that I just can't afford plus the extra mess and time. I spoke to the architect and he is saying usually this is for a flat conversion which I am not doing. Simply adding a dormer to a 2 storey house. He has said that as long as the steels are painted white then the chicken mesh is not needed?
So I am wondering has anyone before had to replace ceilings to meet fire regs and also regarding the chicken mesh if anyone can provide insight on how this is laid is it on the underside of 1st floor ceiling or if it is on top of the joists in the loft and then the existing ceiling is below this?
Please ask me any questions you need I'm also trying to reach out to the building regs and architect but no luck at the moment.
I think my current ceiling are either plaster or plaster lath?
What is the mesh for? Online I can see that it is usually used to keep the floor insulation in place? If so would that not be easier to do than taking down all ceilings and redoing them?
Many thanks
Many thanks
