The pump is a 2 pin connector.i connected a multimeter earth to earth and positive to positive, so the pump must be faulty?
From comments by other members it's likely I have destroyed the ecu
I am confused about the following.this morning I connected a 12 volt voltage from the cigar lighter to the fuel pump connector.i know the resistance of the fuel pump is 9 ohms and it is not shorting to earth.why did the pump not run under these conditions? Terry
