Pyronix Enforcer Alarm Siren Relocation
12 Sep 2025
I wonder if anyone can help me with a Pyronix wireless alarm query. I need to relocate the outside alarm siren as I am cladding a side extension where the box is situated on the front wall. Is it a simple case of unscrewing it off the existing wall (silencing the tamper alarm that will sound) then re-fix it a few inches forward onto the new cladding?
Any help would be appreciated!
You might be fine but you may also end up with an error on the panel that you can’t clear if the tamper goes off. There’s no way of knowing if this will happen up front and like I say, unlikely the panel would have been setup in this way - but not impossible.
Thanks for your prompt replies. So if I were to encounter the error code I would need an engineer to clear it (or the engineer code?). Thanks again.
