Hansgrohe Crometta wand coming apart. How to fix?!
4 Jun 2011
London
The hose has come away from my Hansgrohe Crometta wand. Just pulled out from the wand with no real pressure. Any ideas how to fix?
It feel more like a push fit, maybe a crimped connection, but hard to tell.
1. The ferrule that has come off is crimped onto the flexible hose. This is not a DIY repair.
2. You should replace the flexible hose between the wall connector and the handset. It will unscrew from the handset and the wall connector. Replace with a HansGrohe one, or at least with a big bore flexible connector.
