Brick buster face plate for coax cable VM
25 Sep 2019
Hi, anyone can advise?
What is a better alternative to a brick buster face plate for my outside coax cable? Is the faceplate my best option? The engineer must have not glued it on properly hence why it has fallen off.
Link doesn't work
Ended up getting this. The manufacturer knew what the issues where so adjusted style, hopefully they give the correct ones. I originally had the right side style
Update
Faceplate arrived today, worked a treat, caulking was a nightmare slightly because I stupidly didn't brush the area beforehand so didn't get a nice of a finish. I suppose still looks decent though!
Do. you mean decorators caulking. I thought that was for internal use only.
