Hi, hoping for some advice as my indecision is doing my head in! Vaulted ceiling in 300 Yr old loft where rafters are less than 50mm in some areas so it's pretty impossible to insulate between rafters, even with 25mm stuff. I can get the min u value with 100mm pir so planning to attach the whole lot under rafter and nothing inbetween so have required air gap. Is this a bad idea, and do I still need to put something behind the purlins or risk any condensation finding it's way between purlin and pir butted up against it? Thanks in advance!
