Hello,
We’ve decided to replace the handrail on the steps leading to our back garden with something like this: https://www.dciron.co.uk/products/ssbt11342
The tube is 316 Grade stainless steel, 42.4mm diameter with 2mm wall thickness.
Unfortunately the supplier is unable to cut the tube to the lengths required.
Please can somebody advise on the best way to cut this?
A previous post said that “tube cutters dont do s/steel that thick”. Is that correct?
I did consider a slitting disc in an angle grinder but I’m worried I won’t be able to cut it square enough.
Any ideas please?
Thank you
Any ideas please?
Thank you
