Drain valve in vertical cooper pipe
5 Dec 2012
May seem a bit silly question, but is it okay to install a brass drain valve on a vertical copper pipe (using a T piece) that goes into a radiator valve?
Or do I need to install it on the horizontal pipe run before the vertical?
Only thing I would point out is that you would not be able to drain any pipework below the drain off, if that was the lowest drain point.
