I have changed TRVs before, but only on a normal central heating loop, I have drained the loop then done the job. I need to change the TRV on a bathroom radiator that is connected to the hot water loop. If I turned the cold water off at the stockcock and ran the hot water taps downstairs, would I remove enough pressure from the loop to do the TRV change?
