- Joined
- 11 Sep 2007
- Messages
- 936
- Reaction score
- 11
- Country
M latest Osram LEDVANCE floodlight is starting to fail on me (very dim output) but because of the way it's sealed it's impossible to get inside the damn thing.
So it's time to buy another flood light.
I have two like this:
but while that one in the photograph CAN be opened up pretty easily, later models (like my failing unit) cannot because of the way that they are sealed. If I could open it up it would be an easy fix.
This sealed, non-serviceable issue came about when LEDVANCE was sold to a Chinese consortium in 2018.
So, are there any high quality flood lights which are weather-sealed yet which can also be easily taken apart? It is of course possible to seal them and make it possible to open them up easily, I have a 20 year old flood light with a small halogen tube which is like this.
LED lights of all varieties should of course last for a great many years, but they don't because of manufacturers cutting corners to maximise profits; so not only do you get inferior quality short life LEDs but you also get poorly designed power circuitry using cheap parts which overdrive the LEDs, so causing their early demise, and/or a component in the power circuitry fails. And then of course you can't open the damn thing to fix it ........... It seriously annoys me just how many electronics items can't be serviced these days meaning that when they fail they end up as landfill, so increasing waste and costing consumers money.
Anyhow, rant over.
I've just after a good quality, easily serviceable flood light with a PIR sensor. And not one of the cheap and really crappy Chinese ones either.
Anyhow, rant over.
