- Joined
- 15 Mar 2020
- Messages
- 101
- Reaction score
- 3
- Country
Recently moved into a new house.
Current situation:
- 3 bedroom + office
- Old vented system, cold water tank in loft, very small hot water tank in airing cupboard.
- Boiler is less than 5y, an Alpha E-Tec 20r (been told it is not a particularly good boiler)
- 11 rads in total (including 2 towel rails)
- 3 showers, 1 is electric, 2 with pumps.
- 2 of us, maybe a child in the future!
Not happy with:
- Space being taken in loft + airing cupboard.
- The tank is massively undersized, even for just 2 of us! The shower pumps do a great job, but they empty the tank FAST (especially when using the aqualisa shower).
- Feels very inefficient on the bills, we have always been conscious about this and are used to lower bills, we knew coming into a larger house that we should expect higher bills, but not as much as we are seeing.
Professional plumber/heating engineer has advised that due to the size of the house, it is screaming for an unvented system - this would also require upgrading mains supply, but the flow rate is apparently good enough as is (as measured with cup from garden taps).
Now...
I have always been used to combi systems, my previous house had 1 shower which was fine on a combi, very efficient system. Did not mind the whole "someone using the tap" downstairs, we do not get that many visits, just the 2 of us, our lifestyle never demanded for multiple people having a shower... I'm thinking, why not just get a decent combi? The flow/pressure on this house is much better than our previous one, which already worked well with the combi. Doing basic kitchen tap tests point towards 12.3 L/min. I see (just as an example) a Vaillant ecoFIT Pure 835 35kw should in theory power all of the rads and supply 14.1 L/min.
I believe I understand all the benefits of a modern unvented system, probably as energy efficient as a combi, would provide for multiple showers at the same time as well, heating + hot water at the same time - but I will be honest, none of these things are of particular importance to us, it has never been a factor in our lives. On the other hand, a combi appears to be much more economical from an upfront cost, no need for mains replacement etc...
Would I be making a silly mistake?
Current situation:
Not happy with:
Now...
