So in my bathroom I'm fitting a new sink - the waste pipe runs along the base of the wall, so I'm trying to connect the sink to a T directly below. The gap is roughly 50cm, less when a waste is fitted to the base of the sink.
I know if I place the trap at the usual distance with a drop after, it could siphon the trap. I thought about using two traps, one under the sink, then the fall, then another at the bottom, but I hear that that's not recommended.
So if instead I just have a steep drop from the sink into the trap - probably around 30cm, would this work?
