I have programmed my mk7 galaxy keypad to use keyfobs but when I swipe in front of the reader it beeps and then does nothing do I have to program something else to set and unset using fobs
Yes, once you have programmed the keyfob, you still need to tell the system that the keyfob is used for timed set otherwise the keyfob won’t do anything.
