Column radiator microbore
So I'm getting heat to the flow then the heat is working is way up and across the coloums. But the return is only Luke warm
Not great yet. The flow pipe is hot going too it. Then the heat has started to work it's way up the columns and through the radiator. However the return pipe is only Luke warm.
Yeah I installed the arrow so it flows through the correct way. The baffle forces the flow up the radiator heat is going up to the top of the radiator it is just struggling to return by the looks of it
Because the radiator is getting hot. But can feel much hear on the return. Water must be flowing through it
I did turn the others off and it started to perform better. Though I still wasn't getting much heat on the return pipe to it. I think the boiler cut out water at required temperature. I'm going to try again tomorrow. Just wondered if there was anything I could try
Thanks so the return could still be coldish but the radiator could heat as it is dipisatating most of the heat through the radiator
