- Joined
- 15 Jan 2025
- Messages
- 173
- Reaction score
- 4
- Country
Hello all! I've always wanted to own a pressure washer, mostly for outdoor cleaning.
And i've found one within my budget, it's a
I'm surprised to find that it needs to be supplied water with a hosepipe connection, i had thought it would have an internal tank i could just fill up. But i giess not. This is a bit of an issue, i don't own a hose, and don't really have anywhere made for connecting it
There are three acessible water outlets in my home. The kitchen taps, bathroom taps, and the shower. I don't know if any/all of these would be suitable for feeding a pressure washer, there are definitely special adaptors made for taps to use hoses. I do not have the kind of outdoor tap that is designed for this
Looking in the titan manual, it has this warning section:
i dont know what a backflow preventer is, or whether i have one, no idea how to find out. Is it something i should buy myself? I would rather not modify my plumbing at all
i'm a little bit at a loss here, what are my options for using a pressure washer?
Titan TTB1800PRW
I have not purchased it yet, i'm doing my research first. And i figure what better way to find out what this thing is capable of, than reading the manual, so i found it onlineI'm surprised to find that it needs to be supplied water with a hosepipe connection, i had thought it would have an internal tank i could just fill up. But i giess not. This is a bit of an issue, i don't own a hose, and don't really have anywhere made for connecting it
And that scares meWARNING! This product is not intended to be connected to the
potable water mains!
Observe the regulations of your local utility company when connecting
the product to a water supply line! It is prohibited to connect this
product to the drinking water facility without a backflow preventer which
corresponds to EN 12729 Type BA or EN 61770! Make sure that the
hose is at least a diameter of min. Ø 12.7 mm (1/2“) and is reinforced!
