Pyronix Enforcer
4 Jan 2026
Hi all, new member here.
Apologies if this has been asked before. I’ve installed a Pyronix Enforcer with 2 x PIR, 1 x Door Contact and one arming station.
I will only ever use the app to set/unset whilst at work.
I wan to be able to set it silently, without the buzzer going off.
Any ideas? I’ve tried a few things but they haven’t worked.
Thanks in advance
Just change the requisite Area ? Exits to 0 within the volume control section of the engineering menu.
should’ve added, will be setting/unsetting this while I’m I’m in my car on the driveway.
Got it sorted thanks
Don’t use the arming station, it’s at the front door but we use the back door. Partner prefers using app
There is a seperate volume control for app setting. Set to 0 for silent
