Is waterproof flooring worth it ??
23 Oct 2008
Cleveland
Hi, hope someone can help a confident and competent DIY’er please ?? :)
I’m putting flooring down in a level 2.5m x 3m concrete floor utility room housing an oil fired boiler and associated pipe work, and a washing machine. I tend to overthink things, over engineering things, and go to the far end of a fart to make sure everything is as perfect as possible…..autism is a b’stard sometimes !! :cry: :p
My thinking is to put a 100% waterproof laminate or LVT flooring down to mitigate the risks of flood / leak damage. Is it worth it, or should I just go with much cheaper standard thick hard wearing laminate and risk it ?? I’ve fitted laminate before elsewhere and prefer it to LVT.
Cheers,
Graeme.
Cheap laminate= cheap to replace if there's an issue.
But for proper water resistance, why not just tile it?
Yep, that’s one of my thoughts, if there hasn’t been a leak in there since everything was installed four years ago, just put some cheap laminate in and I can easily replace it (y). I don’t want to tile it, I want something warm for my delicate little trotters :giggle:
If he tiled it could he use electric underfloor heating under the tiles. Left on very low how much £ would it cost every winter. Would it work ? Its the electric underfloor and good ?
Not strong enough for a utility room attached to a garage where there’s going to be all sorts trapped through, but thanks anyway (y)
That is a good point but then cheaply replaceable laminate wouldn’t be either. Also although laminate could be warmer than tiles it is not warm to walk on really.
I know that you are not laying oak but I went from laminate to oak and it actually feels warm to walk/ stand on.
I won’t be tiling it, it’s either LVT or laminate (y)
Good point, but if there's electrics underneath I'd consider waterproofing if that were a feasible option.
Have had a bathroom leak, that shorted out the lights in the kitchen below.
Had a boiler leak in our other property also.
Rarely happens of course.
Plenty of heavy duty vinyls which will outlast
Cheap laminate will be fine if you are just looking for an easy option.
I had an undetected modern crap, thin walled, copper pipe water leak under laminate leaking for months recently. When I took the laminate up to replace the pipe, the laminate was totally unaffected after being protected by the moisture barrier. The same laminate went straight back down (y) ;)
