Unstoppable Mold
How did my great grandparents all live into their late 80s with open coal fires and more industrial pollution ?
I don't have a dog in this fight, but presumably their home was far more drafty and allowed more air in to take the fumes up the chimney?
As does a log burner. Absolutely no fumes from ours. "All Clock stoves not only meet, but beat, industry regulations for performance and lower emissions"
As does a log burner. Absolutely no fumes from mine. "All Clock stoves not only meet, but beat, industry regulations for performance and lower emissions"
Fair call.
I have a number of friends with log burners. My, lay, understanding is that they burn at significantly higher temperatures and the exhaust fumes are less of an issue when they exit the chimney. I grew up in London. Hardly anyone had open fires. As a kid, I recall visiting family members outside of London. They used wood or coal, my irish relatives used turf. You could smell the fuel. With log burners, all I can smell is the timber that was used to start the fire.
As I said, I don't have a dog in this fight .
My present home, was designed and built, to support coal fires, for heating, hot water, and cooking. As such, it had numerous, through the wall air vents to support the combustion, and ensure there was adequate fresh air flow. The fires, and air flow, meant there was no damp, but things are very different now - Those vents are all sealed up, the house is much more warm and comfortable for it, but we have to take a few precautions to reduce moisture in the air, and prevent mould.
Those precautions are - to fit lids on pans, on the hob, make good use of a cooker hood, when cooking, not drying clothes in the house at all, and fit an extract fan in the bathroom.
I was also told by a gas boiler engineer that extractor fans are a waste of time.
Absolute nonsense - as you have proved yourself. You have mould, due to moisture managing to condense, what more proof do you need?
Have you checked for water ingress into the walls? If it's an old house it could be that your external walls are not watertight. If your walls are getting slightly damp from outside, this will facilitate mould growth. If you are doing all the right things re ventilation, then the issue could be from water coming in.
I have used storm dry on the outside bricks which let them breath for 25 years as well as stopping ingress.
Like I said, it gets ventilated and always have the dehumidifier running when showering/bath and afterwards I open the bathroom window.
Not sure what "poor lifestyle choices" is referring to.
Dehumidifier cannot cope with moisture produced in a short time , opening window cools room rapidly encouraging heavy condensation .
Bathroom needs to be warm so it supports airborne moisture long enough for fan extraction ( which you don’t have?).
Significantly shorten your life" ? More chance of traffic pollution doing that. Sorry but that is utter cobblers! Especially if you believe the net zero con by the likes of Ed Miller-bland and his band of nutters. How did my great grandparents all live into their late 80s with open coal fires and more industrial pollution ? My log burner is enclosed and to a high environmental standard. Central heating is FAR more expensive to run with the constant rising prices. And it is cheap to use as I heat water on the top (in sealed pan of course) flask it and use it in the morning to boil the kettle faster. I source a lot of wood myself, dry round the fire (minimal moisture as I don't bring them in wet) Opening the bathroom window gets rid of all the moisture very quickly, especially if windy outside, And when running a bath or shower, the door is kept shut so as not to escape into the house. I was also told by a gas boiler engineer that extractor fans are a waste of time.
No idea where most of that came from or what it has to do with your house being full of mould.
There are many choices you can make.
You have chosen the mould.
I have just been in my bathroom after it being full of steam having had the window open for an hour. Now completely dry and it's cold outside.
The house isn't full of mould, just patches.
Yet you have mould, proof - if any proof were needed, that you are doing it wrong.
