Ecotec plus 831, F53 fault code
9 Jul 2005
Birmingham
Hi all, my 831 has been a little temperamental the last couple of days after a pcb board change. I've read the fault codes and cleared them and the same code comes back, F53. Am I right in thinking this to do with the gas valve? Are these valves repairable by a gas fitter or is it just a swap out?
Many thanks
Jim.
Any gas related work should be carried out by a competent person, ideally someone who is gas safe registered, but you must be able to perform a flue gas analysis afterwards.
You won't get help with that here I'm afraid, as forum rules prohibit giving DIYers gas advice. DIYers shouldn't even be removing the front cover on this boiler - it forms the safety room seal and should only be removed and refitted by a Gas Safe Registered Engineer with the correct tools, knowledge, and qualifications to carry out the Regulation 26.9 checks on completion.
Solution - call a Gas Safe Registered engineer familiar with this boiler
Hi @Jimmyjaffa ,
Have you solved your problem? I'm very interested in your feedback.
I'm also having trouble with the F.53 error code.
I had a Vaillant technician come and replace the venturi.
A week later, the F.53 error code appeared again.
I'm also thinking of a problem with the gas valve.
Before replacing it, I'd like to know your opinion.
Thanks in advance
Hi @Jimmyjaffa ,
Thanks in advance
Hi @Giovanni88,
Have you solved the issue that you were having?
I also had an F.53 fault code. The Venturi was replaced, but the error returned.
Do you have any suggestions on what the problem may be?
Hi, tbh it’s still on going. Mine is very intermittent so I’ve left it. Mine tends to shut down when heating is on quite high and someone’s having a shower. Quick press of the reset and all back to normal. My gas man said it’s more than likely the gas valve at fault.
