Hello,
Please advise: can I connect an overflow to the main roof’s downpipe, from a waterbut that collects water from a gazebo? Distance is 2 meters.
Many thanks!
Certainly not; it's high treason and the water company's monitoring system will detect the extra volume, police will attend immediately and haul you away..
Shame that power socket is there otherwise I'd have proposed moving the butt into the corner and diverting the downpipe through it, but that would make the socket awkward to access, so a long overflow pipe may be the solution. Where does the water from the gazebo guttering go otherwise, if there was no butt?
You could run an overflow pipe around the wall but as robinbanks said, socket is in the way.
You could for a quick fix, attach a length of ordinary garden hose at a suitable height to the water butt, then run that at ground level, around the wall, underneath the socket, and just lay in the soak away.
· Excellent conveyance of, air & powders due to smooth inner surface. Overflow HOSE for water butt - all sizes - quality hose. · The corrugation in the hose gives it strength and flexibility, allowing you to turn tight corners without it kinking.
It wouldn’t be that hard to lay a low level pipe at a slight angle below the power socket, followed by a corner and a short piece (again at a slight angle) to a boss on the down pipe. I am assuming that the down pipe is concerted in. (It is in my house)
Then at the water butt end either one of the corrugated pipes above or more plastic pipe with corner and the corrugated pipe tucked in?
the aim of the angle is to allow it to drain and not remain flooded in cold weather. There is no pressure so push fit would do
