Wylex plug in mcb availability
Yeah plenty of 40/45 on eBay without tab.
They are to prevent the coloured part being fitted into a way that s not rated for 45A
It's getting confusing (at least for me)! Not only have I been looking for a tab that everyone had been calling a notch, but I've also been looking at the MCBs themselves, not the 'base'.
However, that does not materially alter what I am saying - I have one B40 for which both the device and the base have tabs, and another which shows no sign of either device or base ever having had a tab!
No wonder you are confused !
I don't think you can really blame me. This all started when I read the quote from flameport which read ...
... Devices over 30A have a notch which fits into this cutout ...
... which is why I had been looking at the devices (rather than bases), and looking for a notch (rather than tab).
Well on the first way, the bakerlite has a notch to the right of the second screw down.
I take your point that the metal contacts aren’t any different. I guess things improved over time. And then they gave up!
What makes you say that - the position next to the switch looks no different from any of the others to me!
I would say the two contacts look very different. I assume also different isolator, but with the rating written on the back
not easy to see, back when these were used 60 amps was the normal supply.
Copper as thick as what was in those wylex boards can easily take 40 amps.
I'd have to look to see what lines up BUT no that board is not designed to take a 45A device.
OK had another look and as already been said the notch is there and indeed the contacts are a different colour.
Amazing what a difference a pc screen makes over a phone
