And I have. As per previous posts I tested it with my boiler and savings- zero. Post #72As would you.
Shading issue?when the sun comes out it overheats
Per-room would be everyone's theoretical optimum. But it would take a lot of pipework and equipment, and timers and settings could all get complicated.Leaving aside energy savings, I can say with 100%, certainty that our house and lifestyle means zoning is essential (in our case, I'm working towards per-room as other works permit.) Thing are so variable that any setup you might do with a last century approach of thermally balancing the system is unlikely to last long.
For example, the lounge needs heating in winter, but when the sun comes out it overheats even when other rooms (especially downstairs) are cold.
Hence the popularity of combi-boilers, also popular with developers who can shave the space for a cylinder off the size of each property.... plus I suspect that plumbers are all too eager to embrace a theory that means they'll have less work to do.
Doesn't need a lot of pipework - you can do it with actuators on each radiator, replacing the TRV heads on an existing system.Per-room would be everyone's theoretical optimum. But it would take a lot of pipework and equipment, and timers and settings could all get complicated.
No, large south and west facing windows - plus Velux windows. The Velux in north facing roof isn't a problem, but the south facing one adds a lot to the insolation - we've added blinds which help a lot with that.Shading issue?
My working background is in electronics. The last place you want to put electronics or batteries is attached to a radiator, it's well outside of the temperature range of commercial components, and I'm certain they won't be using mil-spec components, as I've seen the price of them. I wouldn't even consider them.Doesn't need a lot of pipework - you can do it with actuators on each radiator, replacing the TRV heads on an existing system.
Microbore was a terrible idea for gas boilers, I don't think it works at all for heat pumps. You need to shift a lot more water around the system as the flow temperature is lower. I'm sure it could be done, but I doubt it would work well at all.If you did want to centralise the valvework, many properties use microbore and one or two manifolds. If going that way, no extra pipework but you do need room for all the valves.
I don't have electronics on the rad - just a thermohydraulic actuator (mains at the moment) - they are a wax capsule with a heater element.My working background is in electronics. The last place you want to put electronics or batteries is attached to a radiator
The electronics shouldn't get that warm unless it's a really bad design. There's actually a relatively poor thermal connection between the valve attachment and the gubbins - it's a design consuderation to make it that way as it has to sense air temperature in most designs.it's well outside of the temperature range of commercial components
Too many people never think about that.Our system is not dependent on any batteries or the internet. The app is an added extra, but if the company who makes it goes bust and shuts down their server it will all still work.
When there was a recent Amazon Web Services shutdown, people using various home automation couldn't even switch their lights on.
